LabWindows/CVI
target types don't show cRIO
Hi Gang,
I'm trying to get a new cRIO Project off the ground for a client.  I have LV 2010 and 2012 on my computer.  I've got the RT modules in both.  I've done one cRIO RT/FPGA project over a year ago.
The cRIO shows "running" in MAX.  Some of the modules can be seen in the remote manager application.  My gut tells me the cRIO is okay.
When I try to create an RT project in 2012, Compact RIO doesn't show up in the list of target types, so I can't select the cRIO Chassis.  Selecting by IP address does put "something" in a project file but no options show up.
I've tried the same thing in LV2010, and all goes as expected, until I try to DL to the RT controller.  It returns an error something like: "RT OS unexpected version" probably a newer version.
I think I'm missing some software, or it is not connected to LV2012.  NI-RIO 4.0 is installed on my computer.  I can see that throught the software tree in MAX.
I didn't expect this part of the project to take even a day to get started, so I'm anxious for help.  I'll appreciate all ideas.
Thanks!
Roger
(3,434 Views)
Hi Roger,
try this question in the LabVIEW board Smiley Wink
(3,432 Views)
Accepted by RogerMont
Hi RogerMont,
You will need NI-RIO 2012:
https://www.ni.com/en/support/downloads/drivers/download.ni-rio--legacy-.html#326649
DylanC
(3,411 Views)
