LabWindows/CVI
Unable to launch CVI 2009
I am using CVI 2009 Full Development Environment, and I am having problem in launching the application.  I can see the flash screen in application starts up, but the screen would just disappear.  There was no error message or any type of dialog prompt.  When I tried to invoke the CVI from TestStand, and that returns the following error message:
Error Code: -17701
I wonder if anyone had similar situation?  And how to resolve?
Thank you.
Peggy
Message 1 of 11
(5,541 Views)
I made a search in the Knowledgebase and found this entry: hope it can be of some help to you.
Message 2 of 11
(5,529 Views)
Thanks for that good find, Roberto. Let us know if that doesn't fix the issue, and we can look into it further.
John M
Message 3 of 11
(5,500 Views)
Hey Peggy -
If this is still giving you trouble, I'd recommend looking at the workaround in this LabWindows/CVI 2009 known issue - it sounds very similar based on your description.
NickB
Message 4 of 11
(5,436 Views)
That fix for corrupted registry sounds like a possible solution, but I have already reimaged the drive and re-installed the software.
Thank you for the hints.
Peggy
Message 5 of 11
(5,427 Views)
Hi,  I guess I shouldn't say the problem went away... Because the CVI refuses to come up again.   I tried the procedure defined in the Known Issue, and I stock at the first step:
Launch Start>>All Programs>>National Instruments>>LabWindows/CVI 2009>>Tools>>Import-Export Settings
The error message that returned to me says: The buffer passed was too small for the operation.
Beside the procedure in Known Issue, I also tried to reinstall the LabWindows/CVI, which it also doesn't work.
Peggy
Message 6 of 11
(5,412 Views)
Were you able to try deleting the registry key directly as noted in the Known Issue workaround?? The Import-Export Settings tool would simply be deleting those keys for you, so a direct approach may be better in this situation.
NickB
Message 7 of 11
(5,394 Views)
Nick,
You're the man! Deleting the registry key fixed this problem for my customer.
With warm regards,
David D.
Message 8 of 11
(5,050 Views)
After a few months of not developing any new CVI code, I was working on a couple of new functions I call from Teststand and I am getting the same error mentioned above, Error Code: -17701 Unable to launch CVI, when I set TestStands CVI adaptor to run an external instance for me to single step the function I wrote.  I have done this many times before on this setup and never had this problem.
I am running TestStand 2010 SP1 with CVI 2010 on Windows 7.
I tried to look at the Knowledge Base Link mentioned in this thread about removing a registery key, but the link does not seem to be valid anymore.
Pete
Message 9 of 11
(4,982 Views)
Hi Pete,
Try this link instead: www.ni.com/white-paper/12156/en#239396_by_Category
Look for known issue 239396.
Message 10 of 11
(4,974 Views)
