LabWindows/CVI
not a valid function file toolbox labwindows7.1
hello,
I have a problem on labwindows 7.1.
when i launch the software labwindows 7.1, I obtain this failure :
not a valid function panel file
c:/......toolbox.h
how can I resolve it, please?
Thanks!!
Adeline
(3,553 Views)
Accepted by adeline62
You probably have this file specified as an additional library. Select Library>>Customize and see if this file is in the User Libraries list. Only .fp and .lfp files should be in that list. You should click the Edit button and replace toolbox.h with toolbox.fp.
Luis
(3,536 Views)
hello,
Thanks for your help!!
It works!!!
thanks again,
Adeline
(3,526 Views)
