05-06-2010 09:24 AM
hello,
I have a problem on labwindows 7.1.
when i launch the software labwindows 7.1, I obtain this failure :
not a valid function panel file
c:/......toolbox.h
how can I resolve it, please?
Thanks!!
Adeline
Solved! Go to Solution.
05-06-2010 04:55 PM
You probably have this file specified as an additional library. Select Library>>Customize and see if this file is in the User Libraries list. Only .fp and .lfp files should be in that list. You should click the Edit button and replace toolbox.h with toolbox.fp.
Luis
05-07-2010 01:32 AM
hello,
Thanks for your help!!
It works!!!
thanks again,
Adeline
