07-29-2020 05:01 PM
I am attempting to rebuild a program that ran on a Windows 7 machine a few years ago. I am currently using CVI 2019 on a Windows 10 machine. Whenever I attempt to build the program (or even just compile a file in the project), I receive the following error message: "1,1 error: error reading 'strcmp(a,b)'. To demonstrate the problem, I have created a very simple program that displays the same behavior. I have rebuilt a couple of other programs on my computer today without issue and it isn't obvious to me what is different about the two that generate the error.
07-30-2020 10:50 AM
You seem to have a Compiler Define statement that is causing that error.
Remove the statement from Options->Build Options in the Compiler Defines field, and you should be able to build and run just fine.
07-30-2020 11:24 AM
Thanks for the tip. I looked at the Build Options setting, but apparently did so too hastily. The old project I was trying to build had this compiler define and it was then copied over when I created the new project. Once I removed it, the new project was successfully built.
