12-04-2014 04:50 AM
I use the driver Ag34970,
I got Project link errors : undefined symbol ...
for all the fuction of this driver.
the instrument is loaded, the .dll is in the project directory, the .h and .fp is added to project.
what is matter?
thank you
12-05-2014 03:51 AM
You should check that the .fp is correctly attached.
Got to Instrument>>Edit menu, select the instrument and click Show Info...
If the Program File is empty it means the fp is not attached to a program file. It should contain a .lib, .obj, or .c file
See here how CVI searches for the Intsrument Driver Program File and put the corresponding file in an appropriate location.
Constantin
10-15-2015 04:18 PM
Thanks that just helped me too!
