LabWindows/CVI
34980A Coding Question
CHECK_MUX(Ag34980a_SetAttributeViBoolean(MuxSession_s,
"slot1com1", AG34980A_ATTR_IS_CONFIGURATION_CHANNEL, VI_TRUE));
"slot2com1", AG34980A_ATTR_IS_CONFIGURATION_CHANNEL, VI_TRUE));
CHECK_MUX(Ag34980a_Connect(MuxSession_s,"1001","abus1"));
CHECK_MUX(Ag34980a_Connect(MuxSession_s,"1008","abus1"));
CHECK_MUX(Ag34980a_Connect(MuxSession_s,"2021","abus2"));
CHECK_MUX(Ag34980a_Connect(MuxSession_s,"2028","abus2"));
I'm using the keysight IVI-C driver (I might just switch over to the class driver at this point).  I'm using the above MUX.  I want to make a 4 wire own measurement, but cannot use the built in measureFresistance function as I am only using one side of the two pole relays.  Here is my setup above for the connecting the relays.  My next question is how do I simply setup the DMM to make a 4 wire measurement now that everything is connected?  I'm not sure why it isn't clear.
(4,415 Views)
Did you mean to attach an image?
(4,388 Views)
No but the code caption didn't show up?
(4,379 Views)
Did the documentation for Keysight Device (34980a) provide adequate guidance? Unfortunately these drivers are not created by NI and are not officially supported. You may be more likely to find support in the Keysight Forum.
(4,354 Views)
