09-01-2006 03:44 AM
09-01-2006 08:43 AM
I'm not sure I understand correctly... here is some info:
From the menu, under "Build", select "Target Type" and choose "Dynamic Link Library".
Also under "Build", select "Configuration" and choose if you want debug or release.
Then again under "Build", select "Create xx Dynamic Link Library", where xx is Release or Debug.
Of course, your code has to be complete with support files etc... Was this what you were looking for?
RayR
