LabWindows/CVI
setting a system environment variable
Does anyone know of a way to set a system environment variable (e.g. path) from either a CVI application or as part of a distribution kit install?
I'd like to simply add a folder to the Windows search path established by the "path" environment variable.
It's apparent how to set the process' copy of an envirnomental variable from a CVI app.  But I want to set the system's enmvironment.
Thanks.
Menchar
(5,663 Views)
Hi.
I have attached a simple Visual Basic script which will modify the registry, appending the folder "c:\menchar" to the Path environment variable.
The script is executed by WSH (windows Scripting Host) via the following system command:
cscript AppendPath.vbs
You can invoke the script automatically after your application is installed (see the Advanced Distribution Kit Options).
Colin.
Note: I am sure it is possible to have the script check the value of the Path variable before modifying it, but I don't know how. I found the relevant info here.
Message Edited by cdk52 on 08-31-2006 05:12 PM
Message Edited by cdk52 on 08-31-2006 05:15 PM
(5,648 Views)
Colin -
Thanks for the info, I appreciate it.
I was looking for something built into the distribution kit.  I could launch the script after the install, the distribution kit provides for running an executable at the end.
Non-CVI applications fix up the path as part of their installation - that's what made me think there should be a way to do it as part of the distribution kit.  Even the reworked distribution tool in CVI 8.0 doesn't directly provide for setting environment variables.
I couldn't find a Win32 API function that would set the system environment - just calls to manipulate the process environment.
I did find where the system environment is maintained in the registry, but if I alter that without a reboot then I would think the path wouldn't update.
Thanks again, Colin
Menchar
(5,618 Views)
Here's some good info on setting environment variables in WindowsXP.
(5,604 Views)
You're welcome, Menchar.
The new path value takes effect immediately; any command window or other app started after the change inherits the updated environment.
I initially looked to the IniFile instrument for a solution, but it cannot handle values of type REG_EXPAND_SZ.
(5,597 Views)
...at least on my PC (running WinXP Pro SP2). This differs from what Microsoft says, so don't rely on it.
(5,580 Views)
