01-14-2009 05:17 AM - edited 01-14-2009 05:19 AM
Hi
When the context menu is launched it defaults to help.jpg (attached).
I would like to define this initial window and also only show help for those controls that have a description.
I don't want the message "No Description available" - maybe I just have to have a desciption for everything?
Any simple solutions?
Al
(sorry please could someone move this post to the LabVIEW forum
I used the browser back button and this setting wasn't remembered)
01-15-2009 04:21 AM
Morning.
Unfortunately you are not going to be able to change the default page on the context help or the information it displays. The Context Help is effectively going to be a password protected VI that does not expose aany properties, therefore you will not be able to make any changes to it. I think yor best solution is going to be making sure that everything has an associated description.
Rich
NI | UK
