LabWindows/CVI
Using a number variable in an SQL statement
I am trying to use a variable in an sql statement and I have run into problems when the variable is a number. The following line of code works if the variable is a string but not if it is a number.
"SELECT TOP 1 UUT_STATUS FROM UNIT_UUT_RESULT WHERE UnitID =  '" + Locals.LocalUnitID + "' ORDER BY START_DATE_TIME DESC"
Is there a difference in the use of the single and double quotes and the + sign for number variables?
Stuart
(3,451 Views)
I'm no expert but I don't believe you need to surround a number within the single speech marks but text does need them. i.e. items in red are not needed.
Kevin
(3,438 Views)
Duplicate Thread
Stuart is right, refer to my post on the TestStand forum:
http://forums.ni.com/ni/board/message?board.id=330&thread.id=22694
Jervin Justin
NI TestStand Product Manager
(3,433 Views)
