02-20-2008 04:04 PM
02-20-2008 05:48 PM
02-20-2008 11:13 PM
Ctrl-E excludes lines of code but this is only a temporary fix. As soon as the project is unloaded this excluded lines are reset. I'm talking about commenting out the code. I guess I'll assume that its either /*comment*/ or temporarily exclude.
Obviously you cannot help me with the person who writes the code. The second question regarding code format is an attempt at improving my understanding of CVI. Part of that is learning about different ways to move code around regarless of whos been assigned to the project with me. Anyone else with suggestions?
Craig
02-21-2008 01:44 AM
Also:
Good luck.
Colin.
02-21-2008 10:22 AM
When you go to close a file that has excluded lines CVI will give you several options:
1) You can comment out the lines.
2) You can #ifdef them out
3) You can unexclude them
02-22-2008 12:49 AM
02-22-2008 11:24 AM
02-22-2008 11:34 AM
02-27-2008 04:26 AM
02-27-2008 10:05 AM
Hello Peder,
Unfortunately it is not possible to "write" a macro in the way that you're describing, which is why the macro language is not documented. You can only record macros.
Are you sure that it isn't possible to record a macro to do what you need? If you're not sure whether it's possible or not, I would suggest that you try to describe here what you need to do, and we will try to help you, if it's at all possible.
Luis
