LabWindows/CVI
LabView PID control with PWM output and Ramp/Soak.
I have LabView 8.5 and a CompacDaq with 9263, 9205, 9472 and 9211 modules.
 I need to build a test fixture that will control two heaters.
 I want a LabView program to have PID controls and PWM outputs.
The PWMs will turn on/off solid state relays to control the heaters.
The program will also need ramp and soak so I can heat and cool the device under test slowly.
Any suggestions?
(4,441 Views)
Accepted by topic author dh2o
Please repost this question to the LabVIEW forum
(4,426 Views)
