LabWindows/CVI
取消
顯示結果
搜尋替代
您的意思是:
Unable to launch CVI 2009
I was having the same problem,
LabWindows/CVI may close unexpectedly when launching.
This issue occurs because of some bad logic when calculating the height of windows in the LabWindows/CVI environment. Most often, this is the result of closing LabWindows/CVI when it has a very small height.
after reading the known issue 239396...
I was able to apply the work around #1 and get going again. Thank you!
0 積分
11 條訊息(共 11 條)
674 檢視
