From Saturday, Nov 23rd 7:00 PM CST - Sunday, Nov 24th 7:45 AM CST, ni.com will undergo system upgrades that may result in temporary service interruption.
09-30-2012 11:34 AM
Hi Gang,
I'm trying to get a new cRIO Project off the ground for a client. I have LV 2010 and 2012 on my computer. I've got the RT modules in both. I've done one cRIO RT/FPGA project over a year ago.
The cRIO shows "running" in MAX. Some of the modules can be seen in the remote manager application. My gut tells me the cRIO is okay.
When I try to create an RT project in 2012, Compact RIO doesn't show up in the list of target types, so I can't select the cRIO Chassis. Selecting by IP address does put "something" in a project file but no options show up.
I've tried the same thing in LV2010, and all goes as expected, until I try to DL to the RT controller. It returns an error something like: "RT OS unexpected version" probably a newer version.
I think I'm missing some software, or it is not connected to LV2012. NI-RIO 4.0 is installed on my computer. I can see that throught the software tree in MAX.
I didn't expect this part of the project to take even a day to get started, so I'm anxious for help. I'll appreciate all ideas.
Thanks!
Roger
Solved! Go to Solution.
09-30-2012 11:49 AM
Hi Roger,
try this question in the LabVIEW board
10-01-2012 10:10 AM - last edited on 06-18-2024 04:40 PM by Content Cleaner
Hi RogerMont,
You will need NI-RIO 2012:
https://www.ni.com/en/support/downloads/drivers/download.ni-rio--legacy-.html#326649
DylanC
