LabWindows/CVI
Resource Name configuration
I am new to LabCVI. I have Sorensen DLM 60-10 power supply. I have communicated with instrument through VISA interactive control and now I would like to communicate using function panel of IVI driver. While configuring that I have used different possibilities of giving Resource Name but it shows error. To find the correct resource name I have enabled the "Extended" Debugging level in build option also. I could not find the correct resource name. Can any one help me out!
Thanks.
(2,364 Views)
Accepted by topic author DGP77
It looks like you are missing the ".." around the resource string.
It should look like "GPIB0::1::ADDR".
Hope this helps..
S. Eren BALCI
IMESTEK
(2,355 Views)
Its works,
Thank you!
(2,336 Views)
