LabWindows/CVI
Real-time OpenMP LabWindows CVI support
It appears that LabWindows CVI does not support OpenMP when using a real-time target.
When I change to a real-time target:
Build -> Configuration -> Manage Configurations... --> Edit... --> Target Settings --> Run-time support: --> Real-time only
This checkbox is grayed out:
Build -> Configuration -> Manage Configurations... --> Edit... --> Build Options... --> Enable OpenMP Support
I could not find any documentation stating that OpenMP is not supported on the RT target. Is the RT target explicitly not supported, or is there another setting I need to change?
(3,384 Views)
Accepted by jkonkle
Unfortunately OpenMP is not supported by CVI in RT environments. You'll need to use thread pools in order to multithread in CVI:
Multithreading in LabWindows™/CVI
https://www.ni.com/en/support/documentation/supplemental/06/multithreading-in-labwindows--cvi.html
B. Poteet
Applications Engineer
(3,332 Views)
Thank you for your response.
Justin
(3,321 Views)
