LabWindows/CVI
Real-time OpenMP LabWindows CVI support
It appears that LabWindows CVI does not support OpenMP when using a real-time target.
When I change to a real-time target:
Build -> Configuration -> Manage Configurations... --> Edit... --> Target Settings --> Run-time support: --> Real-time only
This checkbox is grayed out:
Build -> Configuration -> Manage Configurations... --> Edit... --> Build Options... --> Enable OpenMP Support
I could not find any documentation stating that OpenMP is not supported on the RT target. Is the RT target explicitly not supported, or is there another setting I need to change?
(3,312 Views)
Accepted by topic author jkonkle
Unfortunately OpenMP is not supported by CVI in RT environments. You'll need to use thread pools in order to multithread in CVI:
Multithreading in LabWindows™/CVI
http://www.ni.com/white-paper/3663/en/
B. Poteet
Applications Engineer
(3,260 Views)
Thank you for your response.
Justin
(3,249 Views)
