LabWindows/CVI
Reach fields in several tabs
I have a panel that have several tabs. I would like to retrieve the value of a field from one tab from the callback function of another tab, how to do?
Thank you for help
(2,690 Views)
Hi Taloche,
To make sure I understand your question, you have:
    - Panel 1
    - Tab 1
    - Tab 2
    - Callback function from Tab 2
Goal:
    - You want to make it so you retrieve the return of the callback function from Tab 2 using a control from Tab 1.
Solution (if I understood correctly):
    - You can force a control from Tab 1 that calls on the callback function when its EVENT (such as EVENT_COMMIT) occurs so that the Panel and Control from Tab 2 are the inputs.
For example, this can be the case for a control in Tab 1:
    case EVENT_COMMIT:
        returnValue = CallbackFunction (<Handle for Tab 2>, <Control for Tab 2>, .... );
        break;
Let me know if I misunderstood the question or if there is anything I can clarify.
Vincent
(2,680 Views)
Hi Vincent,
Thanks for your answer, i have find my solution:
I have :
1 panel,
2 tabs with text fields
When it is the Tab 2 that is active I want to be able to read a field from Panel 1. It was just my handle that was not good.
Bests regards
(2,655 Views)
Accepted by Taloche_27
Hi Taloche,
Not a problem. Be sure to mark your response as the answer! This helps other users find the answer quickly and marks the issue to be RESOLVED.
Vincent
(2,647 Views)
