 Ian.W
			Ian.W
			05-28-2008 08:33 AM
Installation Summary
No software will be installed or removed.
Is there a way to change this message to something more informative, such as "The software is already installed" when that is the case?
The reason I ask is it regularly prompts concerned calls from people who think there is a problem with the installer.
I fear the answer is to poke around in the MSI kit with Orca, and if so I'll be submitting a product suggestion!
--Ian
 Mert_A.
			Mert_A.
			05-28-2008 11:49 AM
05-30-2008 09:20 AM
10-21-2010 09:06 AM
Well, I've just been through a round of annoyed/confused users who were caught by this misleading message. They waste time going around in circles and trying all sorts of their own tricks, sometimes creating more problems.
And all along I can just say that I can't do anything about it, which is rather frustrating.
What DLL is the message in?
And can I hack the DLL with a hex editor and change some bytes to improve this message myself?
I'm that desperate.
Ian
 wally_666
			wally_666
			10-21-2010 10:24 AM
Am I the only one that things the Distribution Kit installers have been getting exponentially worse since CVI 5.5?
With CVI 5.5 the installer would fit on two floppies and was easily Emailed as a *.zip file. Now I'm finding it nearly impossible to have a distribution kit below 10MB.
What's worse the 8.x installer won't let two copies be installed into different directories (i.e.. Rename the original to say: installation_old) and then install an update (which may or may not be an improvement from my user's perspective). This side by side testing was pretty helpful in the past. When two copies of the code can't run simultaneously, I use the Windows second instance options to make the second copy fail silently.
 Mert_A.
			Mert_A.
			10-21-2010 01:07 PM
After asking around, I have been informed that this string is actually part of the resources embedded into setup.exe (not a DLL). When you build a distribution, setup.exe is created by copying and renaming [program data]\National Instruments\MDF\BinRTE\msisetup.bin. I tried loading this file in a resource editor, but the strings appeared as garbage. I believe this may be due to compression.
Unfortunately, I can't further support or direct you in this approach. You may be able to find a 3rd party tool that allows you to decompress/edit the resource strings.
I looked into the status of the request I filed (#112285) when you first posted this thread, and it had been rejected. I have reopened it and linked this thread so that it may be reconsidered.
Mert A.
10-22-2010 10:36 AM
Thanks again for your answer and effort, Mert.
If anyone else can chime in with tips on getting at those compressed strings in the embedded resources, I'd be very grateful.
--Ian
10-22-2010 02:33 PM
Success! I was able to use Resource Tuner to edit the string.
This will save me quite a few complaints, and some users quite a lot of frustration. Thanks, Mert!
--Ian
 Mert_A.
			Mert_A.
			10-22-2010 02:57 PM
Glad to hear it! I'm sorry it had to be such a direct, low-level solution.
Mert A.
 msaxon
			msaxon
			10-25-2010 06:46 AM
For what it's worth, the resource strings are also editable in Visual Studio (VS2008 tried, assume others will work as well).
