le 02-09-2022 04:03 AM
One of our customers reported that they are unable to open the popup of the main menu bar on a Windows 11 system. They are clicking on the entry and nothing happens. It worked on their previous Windows 10 installation.
We used LabWindows/CVI 2019 to create this application.
Are there any known issues with this or is there anything I can check?
I don't have a Windows 11 system available right now to verify the problem on my end.
le 02-15-2022 12:18 PM
NI does not yet officially support Windows 11. The most recent version of LabWindows was 2020, which supports Windows 7 SP1 through 10.
le 07-08-2022 11:23 AM
We recently tested LabWindows/CVI 2020 f2 patch on Windows 11 and expect customer applications to work without issue. We found a few minor UI degradation bugs depending on display settings which could be addressed in a future patch.
le 07-09-2024 11:09 AM
is this patch now available?
I have a cutomer who had to migrate from Win10 to Win 11, and is using several screens. The drop lists don't show up where they should.
Thank you
le 08-27-2024 09:06 AM
NI doesn't want to fix this, they tell people to "simply adjust all your monitors to the same zoom level".
I documented a workaround here.
le 08-28-2024 07:45 AM
Thank you very much.
I had a first try; maybe you can modify your very nice code / solution by adding/suggesting to include <windows.h> on the top of the file which should be modified.
Thanks again,
Jean.
