LabWindows/CVI
Measuring CVI code Build execution time
Is there a way to measure the time it takes to build your code (compile/dll creation) and execution? I'm looking at trying to find the difference to perform the build between PC hardware platforms (Core 2 Duo vs Core i3/i5/i7 vs AMD CPUs). Yes, i'm sure the time is really small, but in a high volume environment where every second counts, we're trying to find ways to make things faster.
(3,082 Views)
You can do a small script using the 'compile' command provided by NI
(https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/cvi/usermanual/cmdlineinterface.htm).
Example of minimalist batch:
date
compile Project.prj
date
Or use cygwin and the much better 'time' pre-command.
Guillaume Dargaud
http://www.gdargaud.net/
(3,075 Views)
The link provided by Guillaume is not working here: I suppose he is pointing you to some resource available on the online help too: search in Using LabWindows/CVI >> Managing Projects >> Building a Project >> Using the Command Line Interface (or look here Smiley Wink ).
With reference to execution time, given that you are in a high volume environment you may benefit from the Execution Profiler Tollkit, which is a non-free add on for CVI. Some informations on the toolkit here. You may see an example of how this toolkit can be used in NickB contribution to this discussion.
(3,071 Views)
