LabWindows/CVI
Controls Preferences window won't update
Hi all,
I have a little bug in the my CVI,
Operating system: Win7 64 bit.
CVI: 10.0.0 ( 360 )
at this version at the right side of the window we have 3 windows ( controls names , attributes , help )
The attribute windows worked fine , when I pressed at a single control I saw it's attributes and I was able to change them,
after a while when I added a lot of controls ( something about 100 ) I saw that sometimes a press on a control by this windows wont update and states on the panel attribute
Attached example.
At the example you can see some control is pressed but the attributes are on the panel attributes.
Is this a known issue ?
Edit: after reseting the Workspace the problem is solved.
Kobi Kalif
Software Engineer
(2,894 Views)
It happend again after adding a lot of controls , after reset it was solved.
Kobi Kalif
Software Engineer
(2,889 Views)
