LabWindows/CVI
Line cut command missing in CVI 2013
I just switched from CVI 2012 to 2013.  I would like to implement the line cut command (Ctrl-Y) in 2013, but as far as I can tell there is no line cut command available in the Options->Change Shortcut Keys menu. Is line cut avialable in 2013?
Tony G.
(4,877 Views)
As default, Ctrl+Y is used for Edit/Redo, so you first would need to free this key. In the Change Shortcut Keys window, right click on the line Redo / Ctrl+Y and select Change Key...
(4,870 Views)
I've done that, but there's no "Line cut" entry in the list to assign Ctrl+Y to.
Tony G.
(4,866 Views)
Accepted by TonyG614
I found the cut line command in the "Miscallenaeous" section.  It works now.  Thanks!
Tony G.
(4,863 Views)
