LabWindows/CVI
pci dio cvi code
Hello does anyone have a sample code to drive a NI PCI DIO 96 using lab windows 8.0 or later?
(5,150 Views)
Hi FrankDM,
Depending on which driver you have installed (NI-DAQmx or Traditional NI-DAQ (Legacy)), you will have example code available. If you have the NI-DAQmx driver installed, you can find example code in LabWindows/CVI  >> Help >> Find Examples. If you have Traditional NI-DAQ this article should outline where to find those examples: http://digital.ni.com/public.nsf/allkb/868ED9971759DDC886256D3500743166
The manual for your PCI-DIO-96 should have more specific coding information for the device. Here is the manual: http://www.ni.com/pdf/manuals/374938b.pdf#page=55
I hope this helps!
Rachel M.
(5,123 Views)
