LabWindows/CVI
LabWindows 2013 Database Connection Issues
Edna,
I was able to upgrade my IE.
I have my database set up through the data source tool on each machine where the application is running. I have never had issues with this method before.
I am attaching the file with my database interface.
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
Message 11 of 15
(1,955 Views)
Ok no problem. Let me know what happens.
Applications Engineer
Message 12 of 15
(1,941 Views)
Hi John,
I wanted to follow up with you and see if this issue was resolved. I am currently taking a look at the file you attached to see if there is any direction I can help provide.
Evan See
Message 13 of 15
(1,905 Views)
Hi Evan,
I ended up rolling back the rev on the LabWindows to the latest 2012 version. I have not had time to investigate the problem with 2013 and my database. I am gettin a new PC while retaining my old development PC s I can keep 2012 on the old machine and loading 2013 on the new machine. This set up will give me more chance to investigate.
I pose a question though. My application builds with the SQL Toolkit version 1.1.1. Could that be an issue with 2013? It has not been through all prior LabWindows revs.
John O'C
Woodward, Inc.
Wow...What a Ride!"
Message 14 of 15
(1,892 Views)
It is possible that the older version of SQL Toolkit could be part of the problem. I looked through the previous posts and could not find what OS you are running on. What version OS are you currently and what version had you been previously running?
Evan See
Message 15 of 15
(1,877 Views)
