12-04-2013 08:41 PM
Hi all,
I am using 6711 card and trying to output some samples to analog channel. In the mid way, I will stop the task, redirect the buffer pointer, set the trigger mode and restart the task again. I try the following code
void output(void)
double data[1000];
for (int i=0; i<200; i++) data[i]=8.5;
for (int i=200; i<700; i++) data[i]=4.2;
for (int i=700; i<800; i++) data[i]=3;
for (int i=800; i<1000; i++) data[i]=0.0;
DAQmxCfgSampClkTiming(AO_task, NULL, 100000, DAQmx_Val_Falling, DAQmx_Val_FiniteSamps,1000);
DAQmxWriteAnalogF64(AO_task, 1000, 0, 10, DAQmx_Val_GroupByChannel, data, NULL, NULL);
DAQmxStartTask(AO_task);
Sleep(1);
DAQmxStopTask(AO_task);
// other calculation (not related to DAQ)
DAQmxCfgDigEdgeStartTrig(AO_task, "/Dev1/PFI0", DAQmx_Val_Rising);
DAQmxSetWriteAttribute(AO_task, DAQmx_Write_RelativeTo, DAQmx_Val_FirstSample);
DAQmxSetWriteAttribute(AO_task, DAQmx_Write_Offset, 700);
DAQmxWaitUntilTaskDone(AO_task, 10);
The task AO_task created somewhere else. Above function will be called several times. But I find that it is running without any problem for the first time. But if I call it again, the following error comes out
"The generation is not yet started, and not enough space is available in the buffer.
Configure a larger buffer, or start the generation before writing more data than will fit in the buffer.
Property: DAQmx_Write_RelativeTo
Corresponding Value: DAQmx_Val_FirstSample
Property: DAQmx_Write_Offset
Corresponding Value:700
Property: DAQmx_Buf_Output_BufSize
Corresponding Value: 1000
Task Name: AO_task
Status Code:-200293"
12-05-2013 12:16 AM
@PKIM wrote:
Hi all,
void output(void) { double data[1000]; for (int i=0; i<200; i++) data[i]=8.5; for (int i=200; i<700; i++) data[i]=4.2;
for (int i=700; i<800; i++) data[i]=3; for (int i=800; i<1000; i++) data[i]=0.0; DAQmxCfgSampClkTiming(AO_task, NULL, 100000, DAQmx_Val_Falling, DAQmx_Val_FiniteSamps,1000); DAQmxWriteAnalogF64(AO_task, 1000, 0, 10, DAQmx_Val_GroupByChannel, data, NULL, NULL); DAQmxStartTask(AO_task); Sleep(1); DAQmxStopTask(AO_task); // other calculation (not related to DAQ) DAQmxCfgDigEdgeStartTrig(AO_task, "/Dev1/PFI0", DAQmx_Val_Rising); DAQmxSetWriteAttribute(AO_task, DAQmx_Write_RelativeTo, DAQmx_Val_FirstSample); DAQmxSetWriteAttribute(AO_task, DAQmx_Write_Offset, 700); DAQmxStartTask(AO_task); // other calculation (not related to DAQ) DAQmxWaitUntilTaskDone(AO_task, 10); DAQmxStopTask(AO_task); }The task AO_task created somewhere else. Above function will be called several times. But I find that it is running without any problem for the first time. But if I call it again, the following error comes out
Task Name: AO_task
I am lazy when I type the code. It actually has the error capture on each DAQ function, that's how the error code being captured. But if I remove those error capture, it seems that the code could be run without any problem, I mean if I scope the output, I did see the samples output and the pointer redirected as expect. So why is the error and why it still ouput in the way I set?
12-06-2013 10:36 AM
Do you call this function twice consecutavly or are there other DAQmx functions called between the first time you call this function and the second?
