LabWindows/CVI
IVI error code -1073807360
I'm using a FL8808 in a design.  I can communicate with it using the IVI driver at my bench.  But deployed, I get the following error code:
-1073807360 (0xBFFF0000)
The IVI plaintext error message function in the driver (fl8808_error_message) yields "Unknown status code"
According to this VISA status code page
BFFF0000
Unknown system error (miscellaneous error)
I assume that I have some driver issue on the target machine, though I'm not sure what.  I have a valid COM port when I plug in this Fluke DMM without issue in the Device Manager.
For build installation, I selected these options.  Should I do more?
(1,759 Views)
I found my problem.  I noticed that other applications I've written using the same instrument worked fine.  Similar code.
What I found was a simple bug in this new application.  I had a control get to retrieve the port number the user wants to connect to:
GetCtrlVal(panel, ctrlID, &meterPort);
sprintf(resourceName, "ASRL%d::INSTR", meterPort);
fl8808_InitWithOptions(resourceName, VI_TRUE, VI_TRUE,
"Simulate=0,RangeCheck=1,QueryInstrStatus=0,Cache=1",
&meterHandle);
Turned out that the panel parameter in that GetCtrlVal was wrong!  So I was sending a bad port number.  Duh
(1,678 Views)
