in data 08-15-2023 05:19 PM
I'm using a FL8808 in a design. I can communicate with it using the IVI driver at my bench. But deployed, I get the following error code:
-1073807360 (0xBFFF0000)
The IVI plaintext error message function in the driver (fl8808_error_message) yields "Unknown status code"
According to this VISA status code page:
BFFF0000 |
Unknown system error (miscellaneous error) |
I assume that I have some driver issue on the target machine, though I'm not sure what. I have a valid COM port when I plug in this Fluke DMM without issue in the Device Manager.
For build installation, I selected these options. Should I do more?
in data 08-21-2023 04:23 PM
I found my problem. I noticed that other applications I've written using the same instrument worked fine. Similar code.
What I found was a simple bug in this new application. I had a control get to retrieve the port number the user wants to connect to:
GetCtrlVal(panel, ctrlID, &meterPort);
sprintf(resourceName, "ASRL%d::INSTR", meterPort);
fl8808_InitWithOptions(resourceName, VI_TRUE, VI_TRUE,
"Simulate=0,RangeCheck=1,QueryInstrStatus=0,Cache=1",
&meterHandle);
Turned out that the panel parameter in that GetCtrlVal was wrong! So I was sending a bad port number. Duh
