LabWindows/CVI
Erasing an Edit String Box in LabWindows
When you've exhausted all the possible reasons why it isn't working, the only thing left is the impossible.
First, I am not looking for a LabView answer.  I don't use LabView and don't understand all that visual stuff.  😊
I have no problems erasing text boxes.  But I'm using the password instrument and that requires the box to be an text string, not a text box.  ResetTextBox() doesn't work because it's not a text box.  I've tried SetCtrlVal() and SetCtrlAttribute() but I can't get either to put a string into the text string box.
I have a suspicion that I'm doing something stupid.  But you know how it is, you look at something for so long that the stupidness isn't apparent.
Anyone have an idea?
Dave
(3,404 Views)
You want to use the functions in the PasswordControl instrument, specifically PasswordCtrl_SetAttribute().
(3,383 Views)
Thanks Ian.  I had to find the pwctrl.h file first to see what other functions there are.  There aren't any.
So I implemented PasswordCtrl_SetAttribute(mainHandle, MAIN_RPWD, ATTR_CTRL_VAL, rpwd);
Where rpwd is the string I want.  Still didn't work.  And I've tried writing the field with the SetCtrlVal() and SetCtrlAttr() functions before converting to password, and the password attr function after converting the control to password.  Nothing works.
Thanks again,
Dave
(3,377 Views)
Accepted by d.
If you are using the password control instrument you should already have all that's needed at hand. FYI the instrument is located in <CVI folder>\toolslib\custctrl: di you loaded the instrument from there? Did you actually loaded the instrument? If so, you should see it listed in Instrument menu in the IDE; clicking on it the Select Function Panel dialog should open where you can find all available functions listed, including PasswordCtrl_SetAttribute
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,365 Views)
Hi Robert,
Thanks, that is the answer!
First, I could find no documentation on pwctrl.  I did find the windows opened when you double click the instrument, but I had no clue how to use them.  But after your comments, I browsed around and found that getting a password control attribute value is ATTR_PASSWORD_VAL, NOT ATTR_CTRL_VAL.  So that was my error.
Thanks again,
Dave
(3,348 Views)
Dave, I recommend the Find Function Panel feature (<Ctrl><Shift> P). Assuming the .fp is loaded in your solution, simply putting "password" in that feature will list all your choices.
(3,339 Views)
Thanks Ian.  Now that I know that's there...
Dave
(3,335 Views)
