LabWindows/CVI
Understanding DAQmxErrChk(functionCall)
I  have seen this line in a couple of examples #define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
I would like to understand the purpose of this statement in the code. The argument functionCall to the function DAQmxErrChk isn't declared anywhere. I have searched for documentation that explains the purpose of the DAQmxErrChk but couldn't find any.
Any help is appreciated.
(3,206 Views)
Accepted by topic author SKSV
This isn't a function call, it's a macro! When you run your project the preprocessor comes in first and replaces every occurrence of the macros with their proper code; functionCall is the placeholder for the function enclosed in macro brackets. Thus, the code
DAQmxErrChk (DAQmxStartTask(taskHandle));
gets actually translated to
if( ((error=(DAQmxStartTask(taskHandle)))<0) ) goto Error; else;
(note that DAQmxFailed is actually another macro that is defined in nidaqmx.h)
You can see how code is handled by the proprocessor by running Options >> Preprocess Source File menu function and looking at the new code window that is generated.
(3,146 Views)
For some reason I cannot see Accept as solution Button
(2,946 Views)
Never mind I found it after replying to the post above
(2,944 Views)
