LabWindows/CVI
ENET-9472 installation problem
During my first installation attempt of connecting NI ENET-9472 to NI-DAQmx (whose installation was uneventful), there was an impasse:
In step 6 of Device Configuration (p.8), the instructions say to enter the host name under General Network Settings. This field is not accessable - I can not type in this blank field so I can not finish the configuration; left/right clicks do not open the field. Both Self-Test, Reconnect and Reset Device work. The icon shows ENET-9472 as connected. Everything was new, out of the box, and all instructions proceeded error-free until this point.
Message 1 of 8
(4,436 Views)
Hi steve comee,
I wasn't able to find the exact document you were using but you could try this one.  Good luck, I hope this helps!
Dustin D
Message 2 of 8
(4,414 Views)
The Document was 323489b-01 (Sep08), Getting Started Guide NI-DAQmx for the NI WLS/ENET-9163, that came in the box.
The Test Panels work, but the General Network Settings panel is grayed out and the Hostname field is blank.
Message 3 of 8
(4,404 Views)
Hi steve comee,
Would you be able to post some screenshots of the point where you be come stuck during setup?  That would help me understand what is happening.
Dustin D
Message 4 of 8
(4,366 Views)
Message 5 of 8
(4,349 Views)
just a comment: there is a forum dedicated specifically to NIDAQ, it can be found here: http://forums.ni.com/ni/board?board.id=250
Message 6 of 8
(4,335 Views)
If you click the Reconnect button at the top of the screen are you able to change the settings?
Dustin D
Message 7 of 8
(4,318 Views)
Accepted by steve comee
YES! Thank you. It was so faint, I missed it!
Message 8 of 8
(4,315 Views)
