04-28-2010 11:25 AM
During my first installation attempt of connecting NI ENET-9472 to NI-DAQmx (whose installation was uneventful), there was an impasse:
In step 6 of Device Configuration (p.8), the instructions say to enter the host name under General Network Settings. This field is not accessable - I can not type in this blank field so I can not finish the configuration; left/right clicks do not open the field. Both Self-Test, Reconnect and Reset Device work. The icon shows ENET-9472 as connected. Everything was new, out of the box, and all instructions proceeded error-free until this point.
Solved! Go to Solution.
04-29-2010 12:45 PM
Hi steve comee,
I wasn't able to find the exact document you were using but you could try this one. Good luck, I hope this helps!
04-29-2010 02:31 PM
The Document was 323489b-01 (Sep08), Getting Started Guide NI-DAQmx for the NI WLS/ENET-9163, that came in the box.
The Test Panels work, but the General Network Settings panel is grayed out and the Hostname field is blank.
05-03-2010 10:10 AM
Hi steve comee,
Would you be able to post some screenshots of the point where you be come stuck during setup? That would help me understand what is happening.
05-03-2010 04:09 PM
05-04-2010 12:53 AM
05-04-2010 02:37 PM
If you click the Reconnect button at the top of the screen are you able to change the settings?
05-04-2010 02:53 PM
