LabWindows/CVI
Doulbe User interface
Please help me. Can any body tell me why double screen appears? There is only one user interface file.
Actually after power failure, when Pc restart and I start debugging again. I found this issue.
whenever you clink on either of these files.. only one file will maximize.....
(3,206 Views)
Hi imran,
1. Can you give your computer another restart?
2. Does the same behavior occur if you build it in Release mode (Build >> Configuration >> Release)?
Bdog
(3,174 Views)
Hello imran,
Could it be the same issues as this one?
Try to understand if the solution works for you.
(3,160 Views)
Thank you for your answer.
I tried  many time but problem remains same.
Build >> Configuration >> Release I tried this also but nothing happen.
(3,141 Views)
No. I don think so. it is the same issue. My system works well without any waninig or error but two user interface appears when i move cursor at task bar.
(3,140 Views)
Hello imran,
Do you use more than one panel in your application? If not check if ATTR_TASKBAR_BUTTON is on for your panel.
I found many posts related to this. You can start with this one:
https://forums.ni.com/t5/LabWindows-CVI/Has-Taskbar-Button-and-un-minimized-main-panel/m-p/3754717#M...
(3,121 Views)
