LabWindows/CVI
Image grabbing will decreased on high resolutions?
i am using basler acA4600-10 uc camera device. if set the full 4608*3288 resolution image grabbing will reduces per seconds. but i use the half of the resolution that time will save the image per seconds(fps).  i check my application log file " Image stream is in out of  sync "  show like and Camera block ID show -1 on particular time .  how to solve this problem. can any one help to solve this problem.
Message 1 of 1
(1,753 Views)
