LabWindows/CVI
Does Labwindows/CVI suppport DeviceNet ?
(8,458 Views)
The National Instruments DeviceNet driver does install a language interface for CVI in the form of an instrument driver. These functions are then easily used within any CVI project. If you do not use this driver then you can definitely use any other one via the External Module method with an import library. Go to the following link to download NI-DNET:
http://digital.ni.com/softlib.nsf/16a19f446db24ce5862568d2005b971c/ea18303778b1db14862567fb006f31af?OpenDocument
Jason Foster
Application Engineer
www.ni.com/ask
(8,458 Views)
I don't know what you need , but I know that you can use the C language
function calls provided from Rockwell Software's IOLinx SDK to interface
and communicate through DeviceNet to any device (i/o modules ,drives, OP
terminals...),
You can get more informations at http:://www.rockwellsoftware.com
Best Regards
Samuele Gazzani
AUTECH (Automation Technologies)
Mantova- Italy
bley wrote:
(8,458 Views)
Updated link:
https://www.ni.com/en/support/downloads/drivers/download.ni-dnet.html
Jason Foster
(7,863 Views)
