LabWindows/CVI
Displaying a bitmap in memory
I have acquired an image from a frame grabber in memory in Windows DIB format. I have added the BMP headers so that I can save the file.
I then use the NewBitmap() function to create a bitmapID. The char *image parameter expects the format of the data to be 0xRRGGBB but the bitmap format is 0xBBGGRR so when I display the bitmap to my canvas control the reds and blues are transposed.
After I modified the app to read the same image, that was saved to a BMP file, using GetBitmapFromFile() the image was displayed correctly in the canvas control.
This same function has been built into a DLL that is subsequently used by a LabVIEW application and the image is displayed correctly without having to read from a BMP file.
I used CanvasDrawBitm
ap() to display the bitmap file in the canvas.
Is there a way to have NewBitmap() use the format 0xBBGGRR. Or is there another way to display the BMP file in memory?
NI Software : LabWindows/CVI version 6.0
NI Hardware : None
OS : Windows XP
Randy Schmidt
(3,500 Views)
Hello
The color format used in the NewBitmap() function is pretty much fixed(0xRRGGBB as mentioned in the help), so unless you can byte swap the frame grabber data, I dont think you will be able to use the NewBitmap() directly.
Bilal Durrani
NI
Bilal Durrani
NI
(3,500 Views)
I need to turn a DIB, of which I only have the handle number, into an IMAQ image, or at least into a U32 array, as to convert it into an image. Do you know how can I do that? The DIB comes from an activeX control which controls IEEE1394 camera.
Felipe Llach
(3,500 Views)
