LabWindows/CVI
cts
What is the best way to handle the CTS signal with CVI ?. I've tried to use InstallComCallback() but it seems not to work.
(3,742 Views)
InstallComCallback should work. The callback should be called when the CTS line changes state if you set the event mask to LWRS_CTS.
The other way to do it would be through polling with GetComLineStatus checking for the CTS line to be on.
Best Regards,
Chris Matthews
(3,742 Views)
It's exactly what I do....but I've noticed that when I clear the CTS, GetComLineStatus called from the callback says that CTS is not cleared !.
Is there a trouble inside the Windows driver ? Is the driver waiting a empty output queue before setting/clearing the CTS ?.
Best regards.
(3,742 Views)
I wasn't able to reproduce the problem. I used the CVI shipping example for the serial callback: commcallback.c. And made some simple modifications to detect the CTS state.
Change the mask of InstallComCallback (line 62) to include the LWRS_CTS flag.
Addes some code in the Event_Char_Detect_Func (line 101) callback function:
if(eventMask & LWRS_CTS)
if(GetComLineStatus(portNo) & kRS_CTS_ON)
Fmt (outMessage, "%s","CTS asserted");
else
Fmt (outMessage, "%s","CTS unasserted");
MessagePopup ("CTS change detected", outMessage);
This works perfectly. I'm using Windows 2000 SP3.
Hope this helps.
DiegoF
National Instruments.
(3,742 Views)
Thank you.
I've just found the problem. Windows driver did not write directly the character. So when I write :
a)ComWrite()
b)ComSetEscape ( iPort, CLRRTS);
the second call occurs before all the characters are really written. So the franing is bad.
(3,742 Views)
