LabWindows/CVI
Display images with HWND
Is it possible to display images in a window or any other control that has a Windows HWND other than one generated by imaqGetSystemWindowHandle and imaqGetWindowHandle.
Mark Oberg
(4,449 Views)
Hi Mark,
It's my understanding that all windows will have a message window identifier, and that these two functions will return that window number, so there can be no window that doesn't return a windows handle.
Please respond back with more information.  I might be able to help you further if I get more details about what you are trying to accomplish.
Brandon M.
Applications Engineer
(4,429 Views)
I am trying to display an image buffer in a window that is NOT generated by the imaq Display functions.  So if I created a different window in C++ and used the HWND of that window to use as the display, how would I do that?
Mark
(4,406 Views)
Hi Mark,
in an actual project i'm working with a ueye digital camera. With this
camera i got a sdk that i can use within cvi.
To display the captured image in a cvi window, i first get the HWND:
GetPanelAttribute (videoPanel, ATTR_SYSTEM_WINDOW_HANDLE, (int*) &hWnd);
Than i use the SDK function to display the image in this window:
is_RenderBitmap(hf, 2, hWnd, IS_RENDER_FIT_TO_WINDOW);
In an other project with a canon digital stills camera i just receive the
image buffer from the camera and than draw the image to a canvas on a cvi
panel:
error = CanvasDrawBitmap (viewfinder.handle, viewfinder.canvas, bmp.ID,
VAL_ENTIRE_OBJECT, VAL_ENTIRE_OBJECT);
Hope this helps.....
Norbert Rieper
Bremerhaven
Germany
"MarkOberg" <x@no.email> schrieb im Newsbeitrag
news:1188317424567-571842@exchange.ni.com...
>the imaq Display functions.&nbsp; So if I created a different window in C++
>that? Thanks,Mark
(4,392 Views)
