LabWindows/CVI
Panel background picture
Hi folks!
I am in trouble....
Is it possible to attach a background picture to the panel? How can I do it? Do I need to modify the z-index to do it?
Thank you in advance.
(4,029 Views)
One way would be to put a canvas control on your panel. Make this control the same size as your panel and make sure you set its z-plane order to the back. Simply attach your image file to the canvas and then decide what controls need to have text backgrounds set to Transparant.
JR
(4,018 Views)
I prefer to use other techinique such as attach the image file to the panel, whitout using canvas.
Is it possible?
(4,006 Views)
In other words... is it possible to set a image to picture control file using a popup select file box? How?
Message Edited by Oliveira on 08-28-2007 12:28 PM
(3,999 Views)
The function DisplayImageFile solves the problem.
(3,991 Views)
