05-31-2011 02:20 AM
Hi
I've been reading about Haru PDF to generate a pdf.
Could someone please post an example for Labwindows\CVI? .Im not sure how to get it to work.
One other thing is how can i display the pdf without installing an external program?
Shako
05-31-2011 04:00 AM
I just saw muPDF.
does anyone know how can i use the in my program?
05-31-2011 05:38 AM
just a small note (didn't know haruPDF before...): I use fop (apache-java-tool) to create pdf-reports based on xmls and xsl, works quite nice.
05-31-2011 06:53 AM
Here you can find a sample project for report creation using the HARU Pdf library.
05-31-2011 07:25 AM - edited 05-31-2011 07:29 AM
Thanks.
This shows me much more than what i was doing.
Do you know if there is a way to display a pdf in a CVI panel?
05-31-2011 09:35 AM
You can use an ActiveX container, but you must use the ActiveX interface of a PDF viewer (for example Adobe Reader).
The approach is similar to the WebBrowser example (or other ActiveX supplied samples)
05-31-2011 09:43 AM
i was think of that.
But need my program to be self contained.
Thats the reason why i used Haru for pdf creation.
Is there a way to convert a pdf to and image which i can display in cvi ?
06-01-2011 08:44 AM
Hi Shako,
Have you tried doing a quick Google search for a PDF to image converter? There seems to be lots of options on the web (some free, and some paid). I don't know if I can recommend a specific one as I have never tried doing this before.
