LabWindows/CVI
How do I create a directory within CVI?
How do I create a directory from within CVI?
Message 1 of 12
(7,388 Views)
Creates a new directory based on the specified directory name.
Note:  Only one directory can be created at a time.
/*-------------------- Prototype ---------------------*/
int MakeDir (char Directory_Name[]);
Utility Library\Diretory Utilities
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 2 of 12
(7,384 Views)
This seems really straight forward, but for some reason adding a call to MakeDir gives this error when I compile:
Undefined symbol '_MakeDir@4' referenced in "report.c"
However, I have included utility.h. So I'm not sure what the problem is. Also, the project is real-time only. Any ideas?
Message 3 of 12
(6,843 Views)
Maybe CreateDirectoryA might work (according to http://zone.ni.com/reference/en-XX/help/370051K-01/cvirtmodulehelp/windowssdkfuncsinrt/ this function should be available in RT)
For parameter definition see windows sdk help.
Message 4 of 12
(6,799 Views)
I found kernel32_lvrt.lib on my desktop. I couldn't find any header files. How do I go about including this library in my project?
Message 5 of 12
(6,797 Views)
windows.h
put it at top of your includes
Message 6 of 12
(6,792 Views)
Thanks, I'm having trouble finding documentation for the sdk library.
Message 7 of 12
(6,785 Views)
in CVI: Help/Windows SDK
What i forgot to say: you must have Windows SDK installed with CVI.
Here an extract:
BOOL CreateDirectory(
  LPCTSTR lpPathName,                         // directory name
  LPSECURITY_ATTRIBUTES lpSecurityAttributes  // SD
You can set lpSecurityAttributes to 0 for RT systems.
Message 8 of 12
(6,781 Views)
So am I to gather that the utility.h and/or the MakeDir method is not RT safe?  Is this why it does not work?
Message 9 of 12
(6,691 Views)
I don't know if it is safe or not. I only know that this function is not contained in the RT library.
Maybe a National Instruments representative can answer this question.
In the meantime you can use the SDK funktion.
... and while there is a workaround there is no need to change anything Smiley Wink
Message 10 of 12
(6,668 Views)
