LabWindows/CVI
CVI Application Windows Class Name question
When my CVI application is running and I run Microsoft Spy++, it shows the Window Class Name is "CVIRTLVDChild00400000".
It looks like this is a typical name and if I run different software made with CVI runtime all windows have this class name.
I use another software that may communicate with other running application using their Windows Class Name.
So the question is: Is there a way to modify the Windows Class Name for main window for a particular CVI project?
(3,840 Views)
No, the window class name is actually hardcoded in the CVI Run-Time Engine. I don't believe there is a way to change the name of an existing class name either. You can programmatically get the class name in CVI:
        intptr_t wnd;
	int status = 0;
	char className[256];
	wnd = GetCVIWindowHandle ();
	status = GetClassName((HWND)wnd, className, 256);
(3,813 Views)
Thank you for your reply, D Biel.
I expected that it is not possible since it is too "internal" thing. So I was forced to switch to another solution.
P.S. I hope some day a status bar and "decoration" button will appear in the CVI control list 😉
(3,811 Views)
Hi ZVS,
a status bar has been suggested here and you are welcome to support it Smiley Wink
(3,807 Views)
I would like to support it but did not find how.
For myself I use the Windows Status bar control and it looks and works fine except a callback and control sequence. Screen is attached.
(3,792 Views)
ZVS,
You can just click the up arrow to give the idea kudos. The highest kudo ideas draw the most attention from our R&D department.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(3,774 Views)
