LabWindows/CVI
Blinking text in CVI
Hi there !
I would like to make a text blink thanks to a timer callback. Here is the code of my timer (which has a period of 1sec) callback:
int CVICALLBACK REFRESH(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
    if (bool==1)
        bool=0;
        SetCtrlVal(atlas, PANEL_txt, "   ");
    else
        bool=1;
        SetCtrlVal(atlas, PANEL_txt, "ESSAI EN COURS");
    return 0;
My code is compilling and the blinking is working. However, when I close the program, I get an error on this line :
 with the error message "Library function error (return value ==-13). Invalid control ID ". Do you know where from it could be ? Or do you have another idea to make the text blink ?
Thank you in advance !
(2,991 Views)
Accepted by topic author emilie_grd
Timer controls generate two events: an EVENT_TIMER_TICK at every time interval and an EVENT_DISCARD when the panel containing the timer is discarded.  It appears that when you close your program, the EVENT_DISCARD calls your callback and tries to operate a control on a panel that you've previously discarded.
To prevent this, only execute the code in your timer callback when the event is EVENT_TIMER_TICK:
    if (event == EVENT_TIMER_TICK)
(2,976 Views)
Thank you so much for your answer, now it is working !
(2,959 Views)
