LabWindows/CVI
Use to .uir files
Hello community,
I have four panels on one .uir file and was adding more content, until CVI got out of memory. I searched for solutions and found that I may need to split my content on different .uir files. I did it, but the buttons, gauges, etc that I took away aren't recognized on my main code. I get the next error: use of undeclared identifier
How do I call the new .uir file?
Thanks in advance
(4,261 Views)
Accepted by topic author Lamb25
Hi Lamb25,
A few questions:
1.) Was there a specific message you received when you the CVI "got out of memory"? Like a code of some sort?
2.) Was there an error code for the undeclared identifier?
You should be able to call the panel through the following functions:
static int panelHandle;
int main()
    // Change the panelHandle to whatever handle you would like.
    // Match the name of .uir file to the one that contains your uir file.
    // PANEL swapped to the constant name used to identify your panel.
    if ((panelHandle = LoadPanel (0 , "sample.uir", PANEL)) < 0)
        return -1;
    DisplayPanel(panelHandle);
    RunUserInterface();
    DiscardPanel(panelHandle);
    return 0;
If I am not mistaken, it is likely that the controls when you moved them to a different panel or different .uir's that their constant name changed. You can find out what the new name is in the main project's header file.
Vincent
(4,251 Views)
Of course you need to add the include files for the new UIR files to your code; and pass the correct file name in LoadPanel call.
And you may want to add the UIR files itself to the project: it's not mandatory but it helps getting things clear.
(4,244 Views)
Hello community,
Thanks Vincent and Roberto, both answers helped me.
The solucion was: #include "GAUGES.h"
I call this panel with the button "GAUGES"  and in the button call back the next code worked:
// SEND MESSAGES TO THE GAUGES (BTN_GAUGES: GAUGES)
int CVICALLBACK sendGAUGES (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_LEFT_CLICK:
int error = 0;
/* initialize and load resources */
errChk (panelGAUGES = LoadPanel (0, "GAUGES.uir", PANEL_GAUG));
/* display the panel and run the user interface */
errChk (DisplayPanel (panelGAUGES));
errChk (RunUserInterface ());
SEND_STRING(CS);
SEND_STRING(SN);
turnOffAllTelltales();
Error:
/* clean up */
if (panelGAUGES > 0)
QuitUserInterface (0);
break;
return 0;
(4,227 Views)
Glad to hear that.
Just as a side note, if you aready running the program with RunUserInterface (as you are for sure, otherwise the button callback wouldn't fire), you shouldn't call it again: it is unnecessary and can mess thing up.
(4,222 Views)
