LabWindows/CVI
Automating a LabWindows/CVI program
I have a rather intricate LabWindows program that dates back to CVI 2010 or so. It has been described by users in our testing group as a "swiss army knife", meaning that it has just about every test function you might want, *if* you know what to click in what order.  I've been asked to add automation so that it either self-clicks on things for a given task or at least guides the user into clicking on the right things.
I found the thread "Automating a LabWindows/CVI program" (https://forums.ni.com/t5/LabWindows-CVI/posting-an-event-to-the-event-queue/m-p/823264) which kind of asked the same question. Essentially, if I could have the code place mouse clicks in the queue by button ID I could pull this off. The only real answer offered was to call the callback using a function that no longer seems to exist - CallCtrlCallback().
Are there any tricks for doing this without totally restructuring this code?  The knife blade flips just need to be automated, I don't want to replace the blades or sharpen them.  Thanks!
(2,065 Views)
Accepted by HowardE
CallCtrlCallback () still exists, provided you add the Programmer's Toolbox to your projects. The toolbox can be found in <CVIfolder>\toolslib\toolbox\ folder: you can add toolbox.fp to your project in Instrument menu or better in Library menu: I suggest the latter option since the instrument contains a lot of useful functions that you can find useful for your projects. I use them extensively, and I strongly suggest you to spend some time exploring the toolbox function tree: you may be surprised of how many little gems are there!
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(2,038 Views)
