09-07-2016 11:59 AM
I just moved from Win 7 to Win 10. Now, every application I built under Win 7 or rebuilt under Win 10 "stops working" on exit. I found a couple posts which were similar and posted to one, but got no replies. As another user did, I did a return 0; immediately following main() and I get the same error.
My suspicion is Win 10 and cvirte.dll are not compatible. But I honestly do not know. I saw a similar reference to this in CVI 2015 that was reported by NI as a bug. I don't know if it has been fixed.
Any solutions to this?
Dave
Solved! Go to Solution.
09-07-2016 12:25 PM
Sorry, I've attached a picture.
09-07-2016 05:03 PM
Is this the same problem as reported in this thread? And does the workaround suggested there work? (deleting font files in some folders of the Run-time install)
If not, can you tell us which version of Win10 you are running?
09-07-2016 05:21 PM
Roberto,
I can't tell you how impressed I am that you are a "Proven Zealot." Wish I had that tag.
Curiously, I did see that post before and after reading through the first handful of posts decided it didn't apply to me. But I read through it to the end tried deleting the font folders. My applications now run and terminate properly. Comments in that thread still indicate this is only a work-around.
This is weird though. Years ago (1990's?), you had to install the font directory or your application wouldn't run at all. But for some reason (which I no longer remember), I had to stop installing the font directory with my applications for Windows 10. Since I'm not doing it and my clients don't use CVI, I would assume I can continue to distribute install files without the font directory and they should not have any problems. IOW, the work around is OK for me personally, and I probably won't have to worry about it for my clients.
Thanks for the pointer.
BTW, I'm a zealot too, but I won't get into why here. 🙂
Dave
