LabWindows/CVI
Another possible bug when a popup is open
Some months ago I found a bug when a popup is open (CAR #237405), which has been fixed in CVI 2010.
But now I think I found two other problems related to this one, that is still present in CVI 2010:
  • when a popup is open, some kind of tooltips of the caller panel are generated when you move the mouse cursor.
I attach a simple example, which you can use to reproduce this behaviour:
  1. open the Help >> About popup
  2. while this popup is open, move the mouse cursor over one of the items of the toolbar --> you'll see the tooltip (unexpected behaviour #1)
  3. while this popup is open, move the mouse cursor over the ITEM0 of the "DEMO Tree" in the lower-left corner of the caller panel --> the full name "This is an extremely long name" is displayed in a kind of tooltip (unexpected behaviour #2)
Are these really bugs?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,975 Views)
Hello Vix,
Thank you for your proactive post. I will investigate moreover according to your suggestions and file CAR documents if needed.
I'll give you a feedback ASAP.
Thank in advance and have a nice day!
Matteo
(2,920 Views)
