06-23-2010 07:01 AM
I noticed a strange behavior for popup windows in CVI 2009: when a popup is open, and I click on a button on the caller panel (that I think should be completely inacitve) the EVENT_LEFT_CLICK_UP is generated.
I attached a simple application to show this behavior: in the textbox I append every event generated for the "Click" button. Before opening the popup you can see a lot of events (EVENT_MOUSE_POINTER_MOVE, EVENT_LEFT_CLICK, ...) when you click on this button.
If you click on "Open" a popup is opened; if you click on the "Click" button while the popup is open you will see that the EVENT_LEFT_CLICK_UP is generated.
Could you confirm this is a bug?
The same behaviour is shown for MessagePopup( ), ConfirmPopup( ) and InstallPopup( ).
06-24-2010 02:54 AM
Hi Vix,
Thank you for your posting.
I tested your example project and seen that you seem to be right.
The event EVENT_LEFT_CLICK_UP should not happen when a Modal dialog box is opened.
Now I'm sending a request to R&D in order to let them verify and take the right actions.
I'll let you know if they tell me that this is not a bug but a somehow expected behaviour.
Thanks again
Best Regards
06-28-2010 09:21 AM
Hi Vix,
I'm just writing to tell you that the problem you've found has been recognized and reproduced by our R&D deparment and that the fix will be made in the next version (2010) of CVI.
Thank you very much for your interest and suggestion
Best Regards
06-29-2010 09:17 AM
OK.
Thanks for your help.
06-29-2010 11:55 PM
@luca Gallo wrote:
Hi Vix,
Best Regards
Can you post the car number?
06-30-2010 10:28 AM
237405
07-15-2010 04:45 AM
Thanks for the number.![]()
