LabWindows/CVI
password protected
Hi all,
Is there anyway to make the source code and Panel, pasword protected in Labwindows?
Regards
mhs100
(3,157 Views)
There is no native way to protect CVI code with a password. If you don't want to create and distribute an executable, you may want to split the program into "customer" and "proprietary" sections and create a static or dynamic library for the proprietary half, to distribute without code.
(3,143 Views)
If the goal is to just keep people from modifying the code and UIR files, you could always put the stuff you want to protect in a seperate directory on the hard drive and give read-only access to it.
(3,116 Views)
